- Wed May 20, 2009 1:39 pm
#117856
ok quick question i have a b16a gsr trans with lsd and i was given a cluch masters 8lbs. fly wheel im not sure if i wanna install it or just sell it so i guess waht im asking is what are the pros/cons about it?? if any one knows just let me know thanks!!!
Your engine will rev faster with the 8 lb flywheel which can be fun. But it will also loose rpm faster in between shifts. Unless you are always shifting fast, you may want to slightly blip the throttle to bump the rpm back into range before shifting into the next gear.
I have an 8 lb coupled with a sprung 6 puck on my D16 and this is what I have experienced. (The 6 puck makes your clutch engagement pretty close to an on/off switch)
It's fun and my car isn't a daily driver, but still requires some extra attention and coordination at the same time. If I was going to do it again, I'd probably go with 12 lbs. From everything I've read, 12 lbs seems to be the magic number for civic flywheels.
