By Benj
#76521 ok so my interior is not so hot, grey is the color, and the door panels look like sh!t :x :thumbdown: so i pulled one off today to find that the fabric is the total shits and i was wondering how to fix it, the fabric has come away from the plastic, is there any way of redoing it, i was thinking for a black fabric, anyways back to the issue how do i get the fabric back on after removing it and if i cant remove it how do i fix my issue. Pics here to help
The door panel:
The ISSUE :x
The Back of the panel
any help would be great, thxz a head of time
By GoRide
#76527 u'll have to break the White plaste clips and then do ur fabric.... then when u put it back together use some small screws to hold it back together.... theres a treathed here somewheres on it!
By marvinp8700
#76532 3m makes a spray on adhesive. from what i hear you can drill out the spots holding the panel on and use the adhesive to put the fabric on. then just use interior screws to put it back on the door panel.
never done it but sounds easy enough
By GoRide
#76577 heres my door panel...
By OmarG
#76894
marvinp8700 wrote:3m makes a spray on adhesive. from what i hear you can drill out the spots holding the panel on and use the adhesive to put the fabric on. then just use interior screws to put it back on the door panel.
Its 3M "super 77" spray on adhesive. My drill isn't working so I just got a lighter and a kitchen knife and melted/scraped the pastic rivets off. easy enough. The hardest part is making sure the fabric doesn't have wrinkles or creases when you lay it on the door panel. start from one end of the door panel and work your way to the other side, taking your time. The first attempt of mine, I had to redo the whole damn thing because i tried to lay it all down at once.
hope this helps. :thumb:
