- Thu Jan 26, 2012 8:10 pm
#292104
Here are the plans/changes for 2012.
Purchased parts.
-Endyn 78mm 10.6:1 cpr pistons
-Eagle rods
-Ferrea flat face Stainless valves, +1mm over. (waiting for delivery)
-Spot faced the cyl head so the combustion chamber matches the bore of the cylinders.
-78mm headgasket, OEM honda, opened up by Golden Eagle.
-SpeedFactory thermal intake mani gasket.(waiting for delivery)
-New oem oil pump, ported this time.
-Pulled the trans apart and sent 1st-4th gears in to Liberty gears where they are face plating them.
Needed parts.
-Buy all the rest of my safety crap. Driving gloves, shoes, pants, neck collar.
-Window net and install kit.
-New 13'' wheels, and new 24.5'' slicks. My brother has the Lenso/slick set up I used all last year.
-AEM oil press sensor for logging.
-ACT 4-puck unsprung disc
Want/if funds allow.
-What ever brand LSD I can get my hands on for the trans.
-Try to get some DSS axles.
-MAYBE a different cam.
-Parachute and release cable.
-ATI damper
Cleaned up the block last night. I hated how the Devcon looked. so I cleaned it all off. Block and pistons were dropped off at the machine shop this morning to get bore and hone done. then i'll redo the devcon.
Still need the valves to show up so the head can get dropped off to get the valve job done. Then need to get the crank polished and balanced, along with having them balance the whole set up as far as the crank, crank pulley, flywheel, and pressure plate go.
Out of everythng, i am most excited for the trans lol. I hope it doesnt take too long. They said 3-4 weeks.. :-/ As long as I have it back Before May LOL
Trying to make it to the Vegas IFO event on May 5th. They have an SOHC only class this year. Time to get crackin.
D16z6. Golden Eagle. AFI Turbo. Precision Turbo. Hondata. CG racing.
618hp, 407tq SOHC 10.68@137
My 92 hatch SOHC build. Quest for +600hp. Check it!
