- Fri Feb 08, 2013 3:48 am
#325874
Motor:
F20B Swap
5-Speed LSD
Chipped P28 ECU w/ Street Tune
SKunk2 Adjustible Cam Gears
NGK Iridium Spark Plugs
Aftermarket Intake
Aftermarket 4-2-1 Headers
Stainless Steel Straightpipe (From Headers to Muffler)
OBX Twin Loop Muffler
Mishimoto Aluminum Radiator
Suspension:
Skunk2 Coilovers
Aftermarket Rear Lower Control Arms
Interior:
GSR Gray Leather Seats
ITR Rep Shift Knob
Sprayed Door Inserts
Sprayed Dashboard Panel
JVC Headunit
Exterior:
Aftermarket Headlights
Aftermarket Front Bumper
Aftermarket Front Lip
Aftermarket Spoiler
Aftermarket Taillights
Integra LS Webs
Plansss:
ITR Steering Wheel (You can see the current one is cracked where the bolts connect to the hub)
5Speed Cluster
Bride Vios III - Black
Takata 4-point Harness w/ Harness Bar
TINT! (No A/C is rough here in FL)
Front Upper CA's (Camber Kit - Has an issue with its alignment)
Spray the entire vehicle (especially engine bay) and wheels
Spray Climate Control Unit with the other knobs/switches to match doors
Reupholster Carpeting from the firewall to the hatch
Gauges (Oil Pressure, Oil Temperature, and Water Temperature)
^^ After that it's all motor time! It's already running -mid 13's in the 1/4.
F20B Swap
5-Speed LSD
Aftermarket Intake
Suspension:
Skunk2 Coilovers
Interior:
ITR Rep Shift Knob
JVC Headunit
Exterior:
Aftermarket Spoiler
Integra LS Webs
Plansss:
5Speed Cluster
1992 DX Hatchback
F20B/H23A 5-Speed
_________________
My Build:
http://civic-eg.com/viewtopic.php?t=26194
F20B/H23A 5-Speed
_________________
My Build:
