By forcefedEG
#188803 bov and waste gate on mine both get boost from the same place on my car, i t'd my a vac line and ran it to both, and my wastegate is manual so i dnt need a boost controler, but if you run one you put the controler between the wastegate and its signal source (i believe), some mount them in the car, i dont recomend that, the least amount of line you use on a boost controler the better imo, personally i dont like boost controlers...
By forcefedEG
#188805 and both you wategate and your bov should have a set screw with a jamb nut on the top of them for adjustment... :thumb:
By JUICE
#188807 wastegates have a spring in them that determine when it opens (ex. 6lb spring opens when it sees 6psi). without a boost controller, you run a vac line from the wastegate to the compressor outlet (theres usually a nipple). to raise boost, "t" to a boost controller off this line OR i'm pretty sure you can run a line from the top opening on the WGA (if it has one) to a boost controller.
and your BOV needs tapped to a vac source on the intake manifold
