- Tue Jan 12, 2010 5:16 am
#167765
so as of tonight i now own a civic del sol.. so heres the list
Complete Emblem Delete
JDM Stanley 1-Piece Headlights w/ city lights, very clean
JDM Stanley Fogs
OG Kosei Seneka Wheels 16x7 +42, Satin Graphite Finish
205/40 Yokohama Parada Tires, more than 80% tread life on front. Camber wear on rears.
ARP extended studs(all 16)
KYB struts w/ Ground Control Sleeves (standard rates)
Brand New OEM suspension bushings and bolts.
4-wheel disc
Brembo Rotors
EBC Green Stuff Pads
Energy Suspension Swaybar bushings
New Ball Joints and Tie Rods
Manual Close Ratio Steering Rack
Engine & Drivetrain
JDM H22A Engine,
Ported Intake Manifold w/ butterflies removed and port-matched
AEM OG Gray Cold Air Intake w/ K&N Filter
JDM M2 LSD Transmission
ACT 10# Flywheel w/ stage 2 carbon organic clutch
Hasport Billet Mounts
DSS Stage 2 Axles
Megan Test Pipe
Apexi 70mm Exhaust w/ Flowmaster Muffler
Chipped P28 w/ chrome street tune.
GSR Black Leathers
OEM Original Del Sol Floor Mats
Amber Lighting
OG Grant Wheel w/ Momo hub
DC weighted shift knob, titanium finish
its about to have gen 7 si rims put on it off my hatch.
Negatives
The car has no 5th gear. Period.
Drivers seat has no belt buckle and the rails are not the right rails.
The exhaust has a hole in the Resonator. About a 3X3 inch square.
The Antennae block off plate fell off so there is that hole.
The right rear wheel is not a kosei. It looks similar but isnt one. The 4th Kosei is in the trunk. It needs a small snap in valve stem.
Throwing 4 codes. MAP IAT O2 and Injectors.
Rust coming through on the 1/4 panels.
the damage from the dear.
JDM Stanley Fogs
4-wheel disc
Brembo Rotors
Engine & Drivetrain
JDM H22A Engine,
DSS Stage 2 Axles
Megan Test Pipe
GSR Black Leathers
Amber Lighting
Negatives
"do your own thing to stand out... but dont be a noob n be ricerish!
