- Mon Sep 23, 2019 7:59 pm
#6909002
Well I've got several spare K24s laying around so I stripped one down and cleaned it and decided to setup the intake and turbo manifold and use this as a "jig" to make the new wire harness. Should help me make a great fitting harness since there aren't any off the shelf K24a2 to Haltech wire harnesses. Think I'm going to make a new engine stand that will let me mount the K24a2 and the transmission to it. That way I can test fit everything and all the wiring. I've also gotten the first 4 ID1050x injectors and the DW65c lift pump I will need to get the car running. I'll be running 4 dummy plugs on the bottom of the manifold until I've worked out the bugs and up the boost.
And the heart of the whole new setup.
Just need to order some coolant fittings and pieces from TracTuff and probably an electric water pump setup as well. We will see where I end up going with that.
Instagram:
https://instagram.com/enjoymotorsports
Website:
https://enjoymotorsports.com
Instagram:
Website:
