- Tue May 19, 2009 1:58 pm
#117708
Back in the days when we intended to build a dragracer, Cody Loveland built us a custom B-series front facing twin Tial 44mm (one is 5 psi, other 10 psi spring)wastegated turbo setup. An amazing piece of art, never used. You can use either T3 or T4 flanged turbo.The downpipe exits on the passenger side forward of the wheel.
Unsurpassed quality and durability, unbreakable....
Manifold and wastegates alone were Thousands of bucks, All stuff is new, now the manifold+wastegates+downpipe+ blowofftubes for 750$
this is a bargain people, all new and unused.....
Also for sale is the new and unused turbo for this setup, It's a T4/GT4 Garrett Blowzilla
Product Description
compressor: GT40
.70 a/r
61mm inducer
flow: 65 lbs/min 832cfm
turbine: T4
Q-trim wheel
360* thrust bearing standard
same compressor section as GT35R
Turbo has addtional welded on V-band flange on turbine side, split turbine inlet housing,turbine section was heat resistant ceramic coated and the compressorhousing was stripped of text and polished..
all this cost well over 1700$, now get it for 400$
Also left over from the boost days is an LHT intercooler manifold for a B-series engine. This converts your Jackson Racing B-series supercharger to a liquid cooled supercharger. It allows you to increase boost pressure and not detonate the mixture. We ran it on a 12psi pulley and we had an amazing amount of extra horsepower compared to non intercooled 7-8psi...world of difference....Lht builds these on a core exchange and they modify your existing Jackson manifold. Included is the cooler pump and heat exchanger and a bunch of parts left over from this setup. The charger itself broke down and was not replaced.
LHT charges around 1400$ for this modification, now 350$
Please remember that all items are located in The Netherlands Europe and shipping is not included in these prices and depends on the buyers wishes, what you see in the pictures is what you get, photo's are of the actual items for sale.
Thanks for looking
Best regards
Randall
Product Description
compressor: GT40
.70 a/r
61mm inducer
turbine: T4
Q-trim wheel
Thanks for looking
Best regards
Randall
