- Tue Apr 07, 2009 3:14 pm
#108847
Flow Rate - CC's:
1200 CC's / MIN @ 55 PSI
1090 CC's / MIN @ 43.5 PSI
Flow Rate - LB's:
114 LBS / HR @ 55 PSI
104 LBS / HR @ 43.5 PSI
Resistance:
2.5 Ohms @ 68 F
Voltage:
8-15 Volts, nominal 13.5 Volts
Amperage:
Peak 4.0 Amps / Hold 1.5 Amps
Pressure:
Min 30 PSIG / Max 100 PSIG
I have 100% Brand New PL9-1200's. I bought these injectors last June and have decided to not use them. With the exception of removing one injector from the bubble wrap to look at it they havent left the box. The 4 injectors will come with the balance sheet. I am looking for $350 firm plus shipping. Its a $50 savings from the RC. PM me and let me if your interested.
Flow Rate - CC's:
Flow Rate - LB's:
Resistance:
2.5 Ohms @ 68 F
Voltage:
Amperage:
Pressure:
To Them, they're just vehicles. To Us, they're a way of life.
