- Wed Sep 01, 2010 5:09 pm
#211654
Hey,
So I recently had to swap my throttle body out due to a bad TPS and for some reason after I installed the new throttle body the car won't spark anymore. I've got a '92 EX-V with a D16Z6 boosted to 8psi. I've done a little research and apparently this is something to do with the coil and ICM.
I had a Y8 distributor lying around that I knew was good, so I rebuilt mine with the Y8 parts (Igniter, ICM and coil) but for some reason the car still refuses to spark. It cranks no problem, and the fuel pump primes without any problems. What am I missing?
My thoughts:
Main relay - But probably not because the fuel pump is still priming
ECU
Grounds - Which I've already checked and all seems to be good.
My thoughts:
ECU
