- Thu Aug 21, 2008 1:53 pm
#66941
Thanks for posting this instead of PM'ing me
There's a sticky thread at the top of the D series forum that will answer a lot of your questions:
http://www.civic-eg.com/viewtopic.php?t=10
Either throttle body would fit. I would try using your b7 one first since it has the correct vac lines for your car. If you use your d15b7 TB, then the map sensor will not be an issue, just leave it as is
I used 8 ARP studs for a D16z6 and 2 oem head bolts for a y8 in the back corners. This was back in 2002, ARP might have more options available now.
d15B7 oem head bolts are stretch bolts and should not be re-used. They are about the same cost as ARP head studs, which can be re-used.
