By Sleeping_LX
#208290 another question is: i got the wireing harness for the engine compartment, and the p28 ecu... do i need the 3 clip harness from the ecu into the eng compartment? if so, is there a site to order them? or.. do i just need to add a few wires in for the vtec?
my mechanic and i went to a junkyard and started pulling this out but stopped when we realized it was tied into a big bunch of wires that ran accross the whole dash...
what all will i need to successfully get vtec working properly?
#208291 copied from the Mini-Me DIY:
Looking at the ECU pinout, you'll need to run the vtec solenoid to the A4 pin.
Vtec colenoid on a stock D16z6
There are 2 wires on the Oil Pressure sensor.
on a stock D16z6
The black wire is ground, orange goes to D6 on the ECU
Looking straight into the back of the sensor, the wire in the bottom of the pic will run to the D6 pin on the ecu, the top wire is just run to the chassis as a ground. Just be sure you have the sensor the right way when determining the D6 wire from the ground, hold it and compare the tabs on the outer edge to those in the pic. Use some connectors and heat shrink, do it right. If you can't get the harness clips to connect to the sensors, you can use a small butt connector and cover it with silicone as I did. I filled that back area of the sensor with silicone to make it weather proof.
Here is where you wish you had a 1992 hatch. All 92 hatches were pre-wired for vtec up to the passenger shock tower. Just look at the color of the wires for the A4 and D6 pins on the ecu and find them at the shock tower. Tap into them there and connect your sensors. Otherwise you will have to run the 2 wires through your firewall to your ECU.
By Sleeping_LX
#219552 ok.. update.. all is going well in the building.. got the crank back this week.. was only polished cause the shop said it was beautiful.. and i got new barings (rod and main) thrust washer and rings.. so thats good to go.. will be honing block and reassemblying lower 1/2 this weekend i hope.
have a new question .. the 1/2shafts in car now are shot to shit... im putting in a 99 civic si trans. what options do i have for new ones? i want new shafts, not used.. but i havnt had all that much luck locating them online and im not really sure what ones im looking for. help?
By Sleeping_LX
#219707 also i have a p28 ecu and i was wondering if any1 knows a place in south eastern michigan i can get it chipped for chrom at a decent price??
By Sleeping_LX
#219833 ya.. actually i guess i am... the the eng and trans i got were all bolted together when i got it.. so i know it fits and by what i hear/read its a really short geared trans.. so im lookin forward to the acceleration
By Sleeping_LX
#219967 upon further rewiew.. i have a 99 EX trans. not SI. is a d series. and thru talking to a service guy at a honda dealership i was told that oem halfshafts should be fine. and i think i found someone locally who will chip my p28 with neptune and tune and dyno it for $200. does that sound good/right?
By Fada Blayne
#219986 $200 for chip and tune sounds kool but I'm not so sure about dyno. Make sure this "tuner" knows wat he is doing.
By Fada Blayne
#219987 $200 for chip and tune sounds kool but I'm not so sure about dyno. Make sure this "tuner" knows wat he is doing. Trust and believe the last thing u want is for ur shit to get a fucked up tune. Ask around and see if he can be vouched for.
By Eg6H2D
#220002
Fada Blayne wrote:$200 for chip and tune sounds kool but I'm not so sure about dyno. Make sure this "tuner" knows wat he is doing. Trust and believe the last thing u want is for ur shit to get a fucked up tune. Ask around and see if he can be vouched for.
:thumb:
By Sleeping_LX
#220037 well the guy who pointed me to him is a service tech at local honda dealership.. and i was told to find him on MIhondas.com hes an admin on there i guess. as is the service tech i was talking to.. so hopefully vouches will be plentiful
