By CivicDude
#219259 Just did a JDM d15b swap had 350k on my d15b7 i have more power i love my new motor.
By d16drey
#219336 naah dont listen to that honda tech know it all guy :D
By acereiEG
#219668
Trang wrote:His b7 might have more power depending on how many stickers he had. Or a maybe a turbo? Most likely he was misinformed but still benefit of the doubt.
i bet he had a nice turbo like this one.
By Fada Blayne
#219684 You should know better! That's obviously a supercharger lmao :P
By Torch_Ind
#219759 mahahahaha
I think it's a exhaust bearing lol
By OleFolk
#219807
Torch_Ind wrote:mahahahaha
you mean a muffler bearing :lol:
By Trang
#219844
I heard those give you more low end torque, specially if you go with poly ones.
By Flatland_EG
#219875 I should start a "Ricer Stories" thread. I'm sure most of you have heard some pretty good ones before.
#219941 I got one. When I sold my last EG, one of the test drivers said my car didn't have any power because my RPM was high for the MPH I was going. I tried to explain to him that RPM vs MPH is completely independent of power, it has only to do with gearing. Even shut the engine off while rolling in gear to demonstrate it. He took it like I was BS'ing him, told me that his 90 Civic DX had more power so I told him, "get out, this car is not for sale".
I eventually sold that car with it's 3 stage VTEC to a normal guy who didn't even know what VTEC is.
By Trang
#219956 D15Z7
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 × 84.5 mm (3.0 × 3.33 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm
Torque : 102 ft·lbf (14.2 kg/m, 139 Nm) @ 5300 rpm
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm)
VTEC Switchover : 5800 and 6200 rpm
Fuel Control : OBD-2 MPFI
ECU Code : P2J
Manual Transmission ECU Codes : P2J-003 (OBD2a), P2J-J11 (OBD2b)
Lean burn capable
hopefully it, was what google told me :)
By chilango41
#219958
Trang wrote:D15Z7
3-stage VTEC
Found in:
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
ECU Code : P2J
Lean burn capable
:thumb:
By Trang
#220016
{ikon}EM1 wrote:Sooooo vtec pops twice then??? @ 5800 and 6200rpm???
found this site a couple years ago. Has some info for the vtec :)
http://lmgtfy.com/?q=3+stage+vtec
