#52386 All that weight up front is going to make a difference.
Get it recycled at an AC shop. If you get it in your eyes you could go blind. There's also a little thing called global warming.
It's really not that hard to take out properly if you have big enough wrenches. I took out my complete system and sold it for $350. I literally had every nut and bolt in the following diagrams. I didn't even break the pop tabs.
Don't forget the idler pulley and the evaporator in your heater box. You can get a solid firewall grommet from the junkyard or Majestic Honda. You should also get the condenser block off plate. It makes a big difference aerodynamically.
In fact, try just blocking off the AC condenser with some sheet metal during long trips. You pick up some pretty good gas mileage.
By thedaemon
#63792
OmarG wrote:4) there should be a little aluminun canister which I'm guessing stored the freon (sp) next the the wiper fluid. remove that too. Undo a coupla bolts (If you can get to them) I just beat the thing with a brick until it fell right through.
I hope this helps!
You work on cars the same way I do. I once used a pick axe to beat an engine loose from the motor mounts. Ahh good times. :thumb:
By a_CoUpE
#63872 i had A/C riped it out never used the shit lol, also had PW steering and took that out for looks and other reasons 8)
