- Mon Oct 27, 2008 12:22 pm
#76127
im still using my b7 intake mani.will chenge it to y8 nxt week.oh yah i used 9 b7 head bolts and 1 y8.as of now no check engine light yet.lol.
suspendedHatch wrote:teal_dx wrote:no problem man! Suspended Hatch just wrote a great DIY on adjusting the valves: http://civic-eg.com/viewtopic.php?t=6340
Heyyy... Thanks!
For the head studs you'll need a custom stud for the one in the corner near the VTEC solenoid. 2) PN# AM6.100-1LB DIRECT FROM ARP (1 piece)*"
The rest will be Y8 studs.
You have to use your B7 throttle body so you have that vacuum line for the charcoal canister. You'll need to T in a vacuum line ie the fpr line for the purge control solenoid (the thing in your huge pics).
Some map sensor mount to the firewall, others are right on top of the throttle body. The ECU doesn't care which one. Use the one that works with your throttle body (I believe your B7 map sensor is mounted to the firewall).
