- Mon Nov 10, 2008 11:44 pm
#78171
well let me anser the last questions since i know a definate answer for them
Hydro or cable
Keep it hydro cable only complicates things really i mean yea its just a cable but to tell you the truth daily driving is rough unless you got built legs because you have to push harder I would only use a cable trans if i did a B-swap since they are cheaper but with a D series id stick with the hydro trans just use the one you have already
Obd1 intake manifold?
I would suggest getting one but I would end up getting the ZC speed intake manifold adapter thusly you can use almost any d series intake manifold on the ZC then. makes life alot easier
And on the note of the guy doing the swap for free for the si and the cx motor. I would probaly do that i mean you would end up spending like 500 + doing that with a regular shop and j/w is he gonna do the obd1 swap or are you gonna have to supply the parts if you have to supply the parts idk then i would have to take some stuff out of the si like the seats lol and the ecu definately grab the zc obd0 ecu just because its worth a good amount everyone usually runs with the obd0 cars the 1st gen teg but that ecu dosent compare to the ZC one.....
Anyhow its really up to you in the long run i probaly would do it but id like to see his work first and talk to a customer or two you know....just to get an idea of how things went if it was quick or slow etc...
1980 volvo 242
2001 crv
