- Wed Sep 02, 2009 11:46 pm
#141413
ok guys so far here is my list (the main things)
*Hasting piston rings (75mm)
*ACL Duraglide rod,main thrust bearings(standard)
*Full gasket kit (from FJ Dist.)
*Top Line Oil pump (from FJ Dist.)
*GMB O.E Water pump(from FJ Dist.)
*Timing Belt (OEM from autozone)
I'm gonna get the block's deck resurfaced & honed
and for the pistons & valves i'm gonna
soak them in ATF to get the carbon build off, i hear they ATF is good for that
as for the head i'm gonna get it resurfaced
but i'm gonna leave it alone
unless valves are bent and in that case im will get
a set of 16 valves from FJ Dist. and have the new seats
& new guides put in
and as for the lil things
*OEM thermostat
*NGK spark plugs
*OEM Cap & Rotor
*OEM spark plug wires
*OEM fuel fliter
*OEM alt. belt & power steering belt (no a/c)
*PCV valve
*any hose that needs replaceing
*any sensor that is bad
*dielectric grease on all the connectors
*of course all the fuilds and lube for installation
and for the trans just make sure all the syncor's are good and
make sure it doesnt pop outta gear
and resurface the flywheel and stage 1 cutch
if there is anything else chime in
