#188497 thanks bro for the info :thumb:
By eg84dr
#188501 your welcome dude
i had to do that with my p28 to run vtec
its a bitch job that sucks if no one tells you how to do it
i just used real thin metal to make all of my pins
wish i had just thought to go to a junkyard haha
#188643 ok im poss doin the swap this weekend
and i know for a fact i cant make it to the junk yard anytime soon
so my qusetion is now..
after i do the swap and have the ecu hooked up but not vtec
will the car run weird cause vtec isnt hooked up
and i know it wil have a cel for vtec
#188704 iight fosho, just wanted to make sure it wasnt gonna mess anythin up
By dro21
#189081 What tha your already doing the swap....i hate you man........are you gonna order that rebuild kit of fj distributors?
#189087 ya maybe, my homie is hookin me up, but he needs someone to buy his car..but im depating on if i should trade him for his car..but its a waiting game rite now
and rite now no im not, i need to save up first, but atleast i'll have the motor
#242224 ok im finally doin the swap its all in the car and bolted in
(click sig below to visit build thread to see pics)
its a z6 block but the head is a d15bv
someone told me that ill have valve to piston clearance
is that true?
but this is a kid that think the spark plugs with the ground straps add 15whp.. i just wanna double check bout the head on the block
94_jdm_ferio wrote:ok im finally doin the swap its all in the car and bolted in
is that true?
The head has the same casting, you will be just fine.
#243017 okkk guys i got a problem
im buring oil like no tomorrow and it feels like my b7 was faster then this z6
i was told it was my valve stem seals
now how easy are those to change?
cuz A1 Auto has a top end engine gasket and seal set that i can afford
http://a4.sphotos.ak.fbcdn.net/hphotos- ... 4371_n.jpg
it comes with the valve stem seals
and other gaskets i want
so my question is how hard are they
d-mon said with the right tools its easy but time consuming
By d-mon
#243313 aj, bad valve stem seals won't give you low compression #s.
more likely rings, or blown hg.
i wouldn't go after the head just yet. replace hg first. i can see that it's leaking from your pic on scc.
i have a hg your can use
d-mon wrote:aj, bad valve stem seals won't give you low compression #s.
yeah ill txt you, thanks bill
