By 93hatcheg
#160515 k so i just installed my oem honda lsd tranny on my d16z6 and sarted my car to find after 1-2min the tranny to be covered in oil.....not like someone poured oil on it but like a fim of oil where the tranny turned dark if that makes sense.
it looks to me like maybe the o-ring for the distributor is bad? could that cause a leak that bad? could it be seeping from the HG?? idk at this point
..........dont know if this will help..... the green is what is happening on my tranny (dark area).....the red is where that is happenin on my trans/motor
By ikon
#160517 if its just that side then its most likely the dist. but throw some degreaser on there and when its clean start it up and wait to c where it leaks. a bad o-ring will def cause a leak.
By dipdawg
#160519 mine has the same problem its my dist. o-ring i just havent gotten around to change it
By 93hatcheg
#160523 ok cool guys thanks alot. im going to honda tommrow and buying that damn o-ring along with a new oil pan gasket....it leaks too lol! ill lt you know how it goes.
By 93hatcheg
#160760 whats the best way to fix my oil pan leakin?
By ikon
#160969 ifn its the oil pan its either the drain bolt or the seal. so replace the bolt or get a new pan.
By dipdawg
#160994 Is it leaking from your gasket or from you drain plug. If that o-ring is bad enough the oil from that could be running down the oil pan. Change the o-ring and then clean up all the oil and see if it is still leaking from your oil pan.
By 93hatcheg
#161006 turns out it was the oil pan gasket...i replaced it and no more leak! :) it turns out i just made a mistake when installling the last gasket. thanks for all the help guys :thumb:
