By 95projektvic
#185352 any one know a good quick way to clean the shit out of the intake port holes? :?
By blk92hb
#185378 carb cleaner while the car is running and a tooth pick or pipe cleaners that you used in elementry school just dont let the car die down or let go of the pipe cleaner or tooth pick
By 95projektvic
#185390 carb cleaner wont fuck it up. wat about that lucas stuff?
#185833 Carb cleaner could kill your O2 sensor. They make fuel injection cleaner.
Even then, if you're going to dump a bunch of grease through the engine I suggest you remove the O2 sensor and stick an old spark plug in the hole to plug it temporarily. You should also put some old spark plugs in.
Some repair shops have a pressurized foam machine and they push the foam through your intake and out your exhaust. That's the only way I know to really get it clean w/out removing it.
By 95projektvic
#185910 well got the head off and taken apart. took it to the machine shop to get cleaned and resurfaced. hopin thats all it needs cuz i cant afford anything else.just cleaned the intake with some engine degreaser. taken the oil pan off tomorrow and cleanin up in that area.
By d-mon
#185929 isn't that what seafoam is for?
