By Eg6H2D
#189402 D16Z6 timing points.
ok im about to change the water pump, timing belt and tensioner on my d16z6.
Now the car since ive had it has been good,
now i know before dismantling i have to put the engine at TDC.
now once it's in tdc, and i have things apart, down below. how would i be able to tell if the head and block are timed properly.?
any marks i should look for?..
By Classiccarsrule85
#189411 once you have the crank pully off there a mark on the lower oil pump gear that will signify the bottom end being at tdc and of coarse the cam gear up top has the marks as well....
By Eg6H2D
#189415 ok cool. i know about the top just wasnt sure about the bottom ones. oil pump mark and the crank mark should be point at each other?. right?
By d-mon
#189540 line up the white mark on the crank pulley who the timing pointer on the lower t-belt cover.
the red mark is 16*btdc
