- Thu May 13, 2010 10:53 pm
#194061
i am almost certain that its a starter issue, but i just want to verify with the guru's of Civic EG
when leaving for work, i had started the car without worries, and in the last split second of starting it, it made a weird sound (different than a starting sound), i shrugged it off, because the car was running, and i had to get to work.
after work, i walk out, turn the key, and it makes a weird sound, and does not start... The engine does not spin however.
I am certain the battery is not dead, because all the electronics work, and etc, but the car does not start. It makes a sound SIMILAR to the sound of the fan spinning before starting the car (when placed in the ON position, the fan has a test spin, before starting).
so, would you confirm its the starter?
"It wouldn't need the displacement if it wasn't so pig heavy."
