By kinta94
#198692 my hatch used to run and when i turned it on today all of a sudden it died immideately now the fuel pump doesnt prime and it wont start at all now?
grounds and everything are good cel light is
10IAT - intake air temperature sensor and 21 VTEC spool solenoid valve.
the car used to start and still have these same codes vtec isnt an issue but would the IAT not let the car start? or could i have a bad relay now if so what would of caused to go out?
By 92civic_vx
#198700 check your main relay. turn the key to on and listen for a few click next to the fuse box. if no clicks are heard it probaly the main relay.
thats what happened to mine
By kinta94
#198701 im pretty sure i did hear a click. but im going to go recheck and see.
if i have a click then what?
and is the click from the cabin fuse box or engine bay
EDIT: just checked and i have no click so now im off to find a new relay.
By 92civic_vx
#198702 a new main relay at my local auto parts store is $50 i got lucky a got a good one at junkyard for $2.99
By Eg6H2D
#198703 The Intake Air Temperature (IAT) sensor resistance changes in response to the intake air temperature. The sensor resistance decreases as the surrounding air temperature increases. This provides a signal to the ECU, indicating the temperature of the incoming air charge.
Now what can happen when ur IAT is faulty is..
****Extended crank time when the engine is cold ******
Poor fuel economy
Spark knock .
New IAT is around 20 bucks at honda..
By Eg6H2D
#198704
kinta94 wrote:im pretty sure i did hear a click. but im going to go recheck and see.
Fuel Pump Main relay..
33.99 on ebay. u wil get it in about 2days. Brand New
http://cgi.ebay.com/ebaymotors/Honda-Ci ... 19b2a1a44c
By kinta94
#198708
wait there is a fuel pump relay... i thought that it was part of the main relay i didnt know that there was a second one?
