By gfletcher0913
#200315 Hello,
I bought a 1995 civic and the engine whines. The whine is realted to the RPMs. When I bought it they said they just had a new tmining belt installed. I suspect that I need to ajdust the tension on the belt and the whine will go away.
So how do I know how tight to get the tensioner? Also can I adjust the tension without taking off the crankshaft pulley (and all the other stuff attached)?
Thanks,
G
By TrailerTrash
#200344 you dont have to take the crank pulley off
you gotta pop out one of the little rubber plugs on the timing belt cover get the engine at top dead center and put a breaker bar on the crank pulley after you loosen the tensioner then turn it so far then tighten the tensioner up
thats a very rough description so dont try and do it fallowing anything I say.
#200514 Yeah, basically you need to brace the crank pulley and then tighten it to the torque spec.
