- Wed Jun 23, 2010 1:30 am
#201624
ok here it goes
i had my alt n ac belt and fuel filter and therm replaced and all was good,
then about a couple of days later my dx begins to misfire at idle...then i check the res. for the rad and it is bone dry so I filler( the rad has coolant) up and go on my way...Then two days later i am driving home and my temp gauge goes high then low.... but y i have replaced the therm....I get home and I lift the hood and I c my res. is fine with coolant but i open the rad cap to see nothing.....
So now i think i found the reason for the misfire... oil in the spark plug tubes
but now what going on with my dissappearing coolant ....with no car piss either.... not leaking coolant....
could it b the head gasket who knows... i did have white smoke once but that was it....?
Any help would b muco apprec... b4 i go by a eg coupe and ditch my hatch
