- Sun Sep 12, 2010 12:51 am
#213185
I have a question. Is there a block off plate for the idle air control valve on a D16z6 intake or can I make one? Will i still have an erratic idle?
Simple diagnostic test for after you clean the IACV.
Make sure the intake is off the TB then start the car. Once the car is running cover the TB opening with your hand, if the car dies (and you feel your hand being sucked into the TB a little bit) your IACV is still working and you've eliminated one erratic idle possibility. If the car keeps running like nothing is going on, then your IACV is hosed.
Straight lines are for sissies.
