- Wed Sep 15, 2010 10:38 pm
#213880
my engine light is on for the MAP sensor and i was wondering if that effects the engine idle?
- Thu Sep 16, 2010 12:26 am
#213896
ya if i am right. it should go up and down on ide.
- Sun Sep 26, 2010 12:43 am
#215425
Did you somehow switch the MAP and IACV plugs. I think the have the same pugs and if you switch them it messes things up.
Straight lines are for sissies.
- Mon Sep 27, 2010 9:28 am
#215556
That wont affect your MAP one bit since it measures manifold air pressure. Nothing outside the throttle plate can affect that reading.
If it's not the sensor, then it's the wiring. It's a simple test with a multimeter.
EG_Man wrote:yah i thought of that buy my friend brought up that i have a intake an there might be an air leak in one of the rubber couplings
