By eg84dr
#214073 what oil pump and rear main seal should i use for a jdm d15b
pretty sure i can use the rear main seal from a d15b7 but oil pump im not sure about
d-mon i think did i rebuild so he might be able to help me ?
By Classiccarsrule85
#214075 Id like to say that the rear main seal should be the same for all the d.series as the flywheel for a d-series fits on all the d motors so the crankshaft should be the same so id say any d rear main seal should work and any pre 95 oil pump id use as the ek's had the whole cps on/in the oil pump area as an oil pump from a z6 works on a b7 id say given that it should work on the d15b....
By d-mon
#214164 oil pump and rear seal for jdm d15b are same as d16z6
