- Wed Sep 22, 2010 8:59 am
#214912
Hi guys,
i have a d16a6 mini me (d16z6 head)
I had it rebuilt:
acl bearings (big ends and mains)
Micro polished crank
pm6 pistons standard
arp head bolts
skimmed head 0.8mm
d16a6 head gasket
standard head, cam etc
On first start up every morning i get very very loud piston slap, it sounds like a diesel for 10 mins until its warm 100% then its quiet on idle. when i accelerate between 1500 - 4000rpm (its limited to 4500rpm until its run in as im running aftermarket ecu) it still has a knocking sound or more of a sound like a lose washer is in there or something, then its quite again on idle.. this sound is there warm or cold.
first Q is piston slap bad?
what could the noise be under acceleration?
also my timing belt, tensioner and water pump are brand new, but the timing belt whines very loud!
ive done about 350miles so far on this engine with these noises.. unfortunately its my DD so i have to use it
I had it rebuilt:
arp head bolts
skimmed head 0.8mm
d16a6 head gasket
