By familyEGuy23
#216281 Hey what's up evrybody had some questions about my car and wanted to see if anybody can help..when I'm driving on the freeway after awhile it starts smelling like gas or fumes coming in through the air vents...the motor is stock D15B7 on my 94 civic lx...I don't mind the smell its just it doesn't feel safe with my baby in the car :(
By Honda4life
#216289 Check your injectors and fuel rail. Also if you can yourself, look at both your fuel filters. Are you losing gas? Do you see anything wet in your engine bay?
By Honda4life
#216290 Also check your fuel regulator And no not good for you and your kid to be smelling that for long periods if time
By familyEGuy23
#216360 Thanx for the input Honda4life
I replaced the fuel filter about a month ago thinking it would solve the problem and yes actually I am losing gas.... more than I would think for a civic to be losing
Don't see anything wet and what am I supposed to be looking for in the fuel rail and injectors?
Thanx for the help
By Honda4life
#216370 Your injectors gromets could be worn out and could be leaking because they are worn out. Also check you fuel hoses and Vapor recovery system. You could also have a faulty injector
#216375 double check the bolts on the fuel filter, if you dont have the washers on the filter it can leak fuel, also check the charcoal canister, smell you exhaust coming out of the tail pipe, does it smell like gas??
does the car seem like it has a lil bit more power?? or is it fine??
By ron_kimi
#216381 Maybe it is exhaust fumes i found my leak on the weld of the mid pipe exactly near the shift boot. Try to check your exhaust.
By familyEGuy23
#216424 Thanx for all the input guys ill check it out first thing in the morning but as far as power goes it feels too low for a stock motor :?
By familyEGuy23
#216656 Ok so i checked the fuel lines and hoses...and one the hoses that in on the intake manifold was kinked..going to replace that and see if it works...sorry don't know exactly what it's called i'm a noob to this and this is my first build i'm just going off the haynes repair book,this forum, and everyone's input :lol:
