- Thu Oct 28, 2010 7:53 pm
#220523
ur the shiet!!!
suspendedHatch wrote:Amazing.
People... please don't generalize with AFRs. No car on earth is made to "run as close to possible to 14.7". That car would blow up under WOT and it run and idle like shit. In other words, no car has a single target AFR across all loads and RPM.
At idle the AFR will target 14.5 and slightly richer for a more steady idle. The ECU will target 14.7 at the load and RPM points you encounter during a smog test. Under cruising it will go a lot leaner for fuel economy. I've seen it go over 16:1 on the factory tune, and I've taken it to 18:1 with an AEM EMS. When you let off the throttle in gear above 1200 RPM the ECU turns the injectors off which is an infinite AFR. Rapid throttle changes will cause a brief rich spike to prevent a studder. Under acceleration it will go to 13.5 or so. Under WOT once you cross a certain load point, the ECU will dump as much fuel as it is capable of spraying.
14.7 is stoich which is best for emissions. A richer mixture will make more power, but the actual ratio for max power has to be determined on a dyno. There is no magic number. For fuel economy, you want to lean the mixture as much as you can w/out causing a lean misfire which is the point of swirl combustion and other measures.
No more generalizing!!
ur the shiet!!!
Team XXX Racing/WGHonda
