By PopKorn689
#224960 Hey guys so far in the past month this website has helped me out tons with D series info and I am going to come to you for more help. A buddy just got a 97 DX Hatch and we are thinking of putting the y8 head on it but were wondering what kind of compression and power would be made with this. I'll keep searching for the time being but if anyone knows let me know. Thanks.
#224987 I don't think compression would change at all as both heads have the smaller square-ish shaped combustion chambers. You'd pretty much be converting it to the same specs as a D16y8. :thumb:
By PopKorn689
#224992 Well from what I've researched thus far the y7 pistons have taller pistons or whatever you call it that give it a little bump in compression. Also something about the y8 head gasket being thinner? What's up with that? Again still searching so I'll post what I find and see what ya'll think.
#224993 it will jump from 9.28:1~ too 9.62:1~
By PopKorn689
#225055 Is that just with the head swap or do I need to find the y8 thinner head gasket i herd about?
PopKorn689 wrote:Is that just with the head swap or do I need to find the y8 thinner head gasket i herd about?
yes
here is the cr calutalor
http://www.zealautowerks.com/dseries.html
you can mess around and see what heads on what blocks wit wich pistons do wat :thumb:
By PopKorn689
#225119 I love that page! Thanks a ton! According to that calculator I'll be looking at 9.9:1 Compression with a y8 head on a y7 bottom and if I can locate this mythological 2 layer y8 head gasket it'll be around 10.25:1!!! :woot:
PopKorn689 wrote:I love that page! Thanks a ton! According to that calculator I'll be looking at 9.9:1 Compression with a y8 head on a y7 bottom and if I can locate this mythological 2 layer y8 head gasket it'll be around 10.25:1!!! :woot:
i think honda sells them, not sure, but ya i like that site too, u can do h/f's k's and b's and transmissions too
By PopKorn689
#225148 Well nobody has a part number for it or I can't find any posts that actually verify such a head gasket is even a real thing. I was actually laughed off another site for asking.
#225149 i guess you gotta get the 3layer and take the middle layer out
By OleFolk
#225217 cmon someone
You know a D16 three stage vtec sounds sick right?
Edit: Hell we can call it a D16B :lol:
OleFolk wrote:cmon someone
wahhhht
lol
d16b vtec 8)
By d-mon
#225229
94_jdm_ferio wrote:i guess you gotta get the 3layer and take the middle layer out
that is correct, AJ.
i don't recommend doing this.
just mill the head if you want a noticeable compression bump.
