#228293 ok I thought about this... is this going into a civic vx? if so, you'll have a vtec-e ecu and a vtec head which will mean the wrong air/fuel curves and incorrect vtec crossover point. The easy way around this is to swap ECU's but then you'll need to convert to a 4 wire o2 sensor if this is a VX civic you're talking about (they come with a 5 wire o2).
By EJ1STYLEN
#228920 what about on the b7? that would be a sorta good combo good MPG + Vtec...
