- Thu Dec 23, 2010 5:13 am
#229428
You can boost the d15z1, I wouldn't go over 200hp on stock block.
The Vtec-E will probally work real good with a Boosted setup as vtec-e will help with low end torque and then boost will take care of the top end.
The VTEC-E heads are the only d or b series head to have Roller Rocker Cams, which is pretty cool. They are low compression from the factory. Having a Boosted d15z1 would be a cool setup. When the bottom end eventually pops swap it out for another d15 bottom end like a d15b7. Parts will be cheap, it will be decently quick. However you wont be problem free.
If you want n/a power go any B Series besides the B16, and use a B18c(gsr) Transmission or a b16 transmission. Your car will be quick. On the down side parts will be more expensive, however you will be quicker then a Boosted d15z1.
I would be tempted to do a Boosted D15z1, However I also have Tons of extra D Series parts including mutiple bottom ends, another car for when its brakes down and am confident that I can pull a engine, swap blocks and put a new one back in in less then 10 hours. If you dont have all the Tools, or extra parts(or money for extra parts), or anouther car to drive when it eventually brakes down(oil leaks, blown seals, charge lines come off, turbo goes out, etc) then it wouldn't be a good idea.
