- Tue Jan 04, 2011 11:41 pm
#231468
This is referring to obd1 honda chassis only (obd2 chassis is a bit different since they have 2 types of ecu and harness of type a and type b).
obd1 harness use on all obd1 chassis all connectors will fit fine. some cx/dx/vx came with one wire or the 5wire o2. You would have to repin. Vtec if you didnt have it on the harness like the lx/dx/ls/cx then pin up directly to ecu.
obd1 harness on obd0 honda motor can be done. changing distributor/alternator/injectors or cut and splice obd2 plugs.
obd1 harness can be used on any obd2 honda motor by changing alternator/distributor/fuel injectors to obd1 or cut and splice obd2 plugs.
Your choice.
