#237166 D16z6 are not usually bored more than .020 (75.5mm) because they don't have as much material to remove as a B series.
To get to 1.7 L, you would need to increase the stroke.
By honda power
#237171 say i sleeved it how much would i need to bore to make it a 1.7
By Butterzz
#237181
teal_dx wrote:To get to 1.7 L, you would need to increase the stroke.
By honda power
#237197 ok im not tryin to sounds rude here but im not looking for anyones opinion, thoughts or advice im just lookin for an answer to my question..... please and thank you
By Butterzz
#237229 Im not trying to sound rude either.
You cant overbore a D series from 1.6L to 1.7L. You need to change the stroke. The cylinder walls literally aren't thick enough to support it.
By honda power
#237264 thanks thats all i wanted... you can bore darton sleeves out to 78mm max so .040 over should be safe and with the 1.7 crank and that bore i would be running a 1.8 sohc
