- Mon Feb 07, 2011 9:54 pm
#237478
So even with my experience with hondas i cannot get my old hatch to run again....it needs to get out of my backyard and well the kid who is buying it wants it running and will pay me 150 more if i can get it done asap but i cant figure it out
-so far if tried different ecu's all for the d15b7
-and swapped over my main relay from my hatch which i know works....
this hatch is a 1995 civic hb with a d15b7 in it i just recently did the swap and finished buttoning it up and went in to turn the key to prime the fuel and rotate the engine and nothing the main relay clicked and when you go to turn the car over nothing no crank....
so since the ecu was old i swapped it out for one i knew worked and my main relay no change you dont even hear the fuel pump kick on....
my biggest worry is something happened majorly to the car (big fat chance that nothing happened) but something had to as with my past swaps into the car everything was fine and dandy started right up and everything....
any help would be greatly appreciated.
Some things that i havent tried yet but am thinking that it may be
-SRS system? i dont think it has a fuel cut off and engine stop but maybe I normally rip all that out so i dont mess with it just this kid wanted it so i put it back in....
-possibly the starter but that wouldnt make the fuel not flow it just wouldnt allow it to crank over....ugh so frustrated!!!
1980 volvo 242
2001 crv
2001 crv
