- Mon Feb 21, 2011 10:15 pm
#240106
To start with, my car broke down on the Hwy... I noticed it smoking from the top of the timing belt cover and some of the plastic of the top timing chain melted.. I may have been low on oil. Resulted that there was no compression in all cylinders. I took the cylinder head apart , shaved the head, replaced the timing belt, head gasket, waterpump and put it all back together again but to my dismay nothing improved. I still have '0' compression in cylinders 1.2 & 4... with about 30 psi in cylinder 3..
I do not know if I may have a problem with the valves, pistons, rings...etc. Where should I go from here ???
1992 Honda Civic LX
