By honda power
#241240 anyone ever hear of this d series 185 stock hp i want one
D16B5
(Identical to the D16Y5. Main differences are Pistons, Rods, Camshaft, Head Gasket, Intake Manifold, and Exhaust Manifold are PDN rather than P2M)
Found in:
1998-2000 Honda Civic GX
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 × 90 mm (3.0 × 3.5 in)
Rod Length : 137 mm
Compression : 12.5:1
Combustion Chamber Volume : 32.8 cc per cylinder
Power : 185hp @ 8500 rpm
Torque : 160ft·lbf (? kg/m, ? Nm) @ rpm
Valvetrain : SOHC VTEC-E
VTEC Switchover : 5700 rpm
Fuel Control : OBD-2 MPFI
ECU Code: PDN-A02
By d-mon
#241665 all the civic GX's i've seen use natural gas instead of gasoline.
the gas company leases fleets of them from honda.
and the motors have nowhere near 185hp.
By honda power
#241694 im not sure iv never herd of one of these i found it on wikipedia so you can never trust what you find on there
