By Dirtymechanic87
#242748 I've got a d16z6 with a comp cam, zex springs, zex spring retainers and a mild port and polish. What my ? is that my valves are really noisy, I've already adj them tighter than spec. They are at .005" intake and .008 exhaust right now, how much tighter should I go?
By Eg6H2D
#242789
Dirtymechanic87 wrote:I've got a d16z6 with a comp cam, zex springs, zex spring retainers and a mild port and polish. What my ? is that my valves are really noisy, I've already adj them tighter than spec. They are at .005" intake and .008 exhaust right now, how much tighter should I go?
Lol.. go to the main page of the D series engine. and from the top look down about 3-4 posts...
Smh..
By Eg6H2D
#242790 Actually let me make it "EASY" for you.
:roll: :roll:
http://civic-eg.com/viewtopic.php?t=6340
By Eg6H2D
#242792
and it's .007" on the intake and .009" on the exhaust. where did u get your info from?
By Dirtymechanic87
#242803 I already set it to stock specs the first time, then I went tighter to see if it would help. It did a little just wanted to know if I could go tighter and if so how far?
By Eg6H2D
#242806
Dirtymechanic87 wrote:I already set it to stock specs the first time, then I went tighter to see if it would help. It did a little just wanted to know if I could go tighter and if so how far?
bring it to the above mentioned values,. that's the D series stock settings. if you still have the sound. then you might have to look at your lost motinio assembly..
