- Sat Mar 19, 2011 5:42 pm
#244869
My d16z6 motor is losing oil without no oil leak anywhere. There is also no oil leak in the engine bay area. Every month i would add one quart. What is the problem with my motor and the oil keep disappearing? its daily driven.
- Sat Mar 19, 2011 6:01 pm
#244876
You might be burning it
- Sat Mar 19, 2011 8:42 pm
#244898
as said above, its probably burning it. oil doesnt disappear
- Sun Mar 20, 2011 4:43 am
#244958
why is it burning oil then? what can i do, get another block?
- Sun Mar 20, 2011 2:27 pm
#245014
Rings could be bad, valve stem seals could be bad. Have you checked to see if there is oil in your coolant ... maybe your head gasket is having some issues.
There are all sorts of reasons to burn oil.
Straight lines are for sissies.
- Sun Mar 20, 2011 3:16 pm
#245026
i heard the piston ring could be bad but hasnt sure. there is no oil in the coolant too and the head gasket seems to be fine to me, there is no over heating. this has also been going on for a long while now. i just wanted to ask make sure how serious the problem could be. maybe get another block that wont eat oil.
AutoXCivic wrote:Rings could be bad, valve stem seals could be bad. Have you checked to see if there is oil in your coolant ... maybe your head gasket is having some issues.
- Sun Mar 20, 2011 3:42 pm
#245030
How many miles are on your engine?
- Sun Mar 20, 2011 4:54 pm
#245041
blocks dont eat oil.
- Sun Mar 20, 2011 5:43 pm
#245049
im not sure. my older bro had it before i did. the original 1.5 b7 head gasket blew so he bought the z6 at a salvage yard. not sure if it oil was already burning.
lmao right but you know what i mean.
teal_dx wrote:How many miles are on your engine?
TrailerTrash wrote:blocks dont eat oil.
- Sun Mar 20, 2011 5:44 pm
#245050
what you guys suggest i do?
- Sun Mar 20, 2011 6:11 pm
#245052
one quart per month isnt too bad. I would drive it like it is unless it smokes when you are on the gas. There are ways of telling where you are losing oil.
After your car has sat overnight pull a sparkplug and see if there is oil sitting on your piston. If so then its prob Your valve cover seals leaking.
oil in antifreeze as suggested above.
It is most likely your rings. There are rings designed to maintain a certain amount of oil on your cylinder walls that stop functioning properly as they wear out. The more miles your car has (in general) the less these rings are able to keep oil below the pistons.
A simple check to see if your rings are worn is to do a compression check. Usually the compression rings wear at a fairly consistant pace with the oil rings. However, good compression does not guarantee that your oil rings are good.
Another way to check that only works if you have a fair amount of burn is to have someone rev your car to high rpms while you watch the exhaust to see if ANY blue smoke comes out.
Buying a used bottom end will probably just give you the same problems. The best thing you could do would be to find a d16 bottom end and rebuild it yourself. Or order from a motor import place for a few hundred+ bucks, IF its your rings.
94 blue lx sedan (sold)
95 black ex sedan (wrecked)
93 white z6 del sol (Sold)
95 red y8 hatch (sold)
98 red coupe
98 red coupe
