- Thu Apr 14, 2011 5:32 pm
#250412
ok so i did a mini me swap on my friends 92 hatch a couple weeks ago car worked fine after the swap was finished except a weird idle it would sit around 850-900 and occasionally drop down to about 4 or 500 then back up and very rarely it would stall out. worked great tho not a problem great fuel millage as good of power as your going to get from a stock d really no complaints other than the idle. yesterday he started the car up fine doesnt smoke, idles normal, revs up ok doesnt sputter to bad untill you drive sounds like a wrx just gutless, no power and doesnt want to move.
heres everything we've tried so far.
-checked all sensors and hoses- fine
-the ecu used is a chipped p28 with a gsr base map, with the wire cut to bring it back to stock. tried using a p06 we had and still the same if it was an ecu issue the p06 should have made it run better.
-timing? no timing gun to check if its exact but it worked fine before and the timing belt is still tight not sure how it would have slipped it, belt still torqued to spec. tried moving the dizzy to both extremes to. also cleaned the dizzy
-changed the fuel pump and fuel filter is 6 months old always ran 91 octane
-spark plugs look fine nice and clean looks like everything is running right
and its running on all 4.
and no cel
mini me swap
non vtec sohc zc block(sleeves looked like new)
new water pump, timing belt, tensioner.
new head gasket, intake gasket
d16z6 head
d15b7 intake mani/ tb
airmass 4-2-1 header
not sure what else i can add right now im kinda stumped here would really like some input please
driving it today it was alright at first once warmed up and driving normal it just cuts out sounds like its misfiring or something really sounds like an wrx sti.
burnt valve?
and no cel
mini me swap
d16z6 head
burnt valve?
