- Wed Jul 27, 2011 2:34 pm
#265197
Hey guys im new to the honda sceen an have a 94 civic coupe it has a d15 with a shitty automatic can someone explain to me what i have to do to find out what manual transmission i need to buy to convert to a 5 speed an any extra info would help an be greatly appreciated thanks guys
- Wed Jul 27, 2011 2:43 pm
#265198
any manual transmission from 92-95 will work. You will need: tranny, clutch/flywheel/pressure plate, ECU, starter, auto to manual conversion mount ( http://www.innovativemounts.com/Product ... Code=49520 ), front manual tranny mount, clutch slave cylinder, clutch master cylinder with resevoir(i suggest one from an Integra due to the resevoir and cylinder being attached), all hydro lines from tranny to master cylinder, pedals(clutch and brake), shift linkage, shifter, shift knob, shifter bushings, flywheel cover plate, connector for the reverse lights on the manual trans.
most of this can be found at a local junkyard.
