By xjm92x
#266542 y8/b7 mini me make some sort of howling sound after it heats up compression is low on take off but i think its because im missing a valve cover bolt?
By TrailerTrash
#266548 what do you mean by the compression is low on take off?
By xjm92x
#266551 like after a while of driving if i press the gas it takes a few seconds befor the car starts moving but after that its gone but that only happens when i stop
By xjm92x
#266635 Ok during acceleration i can hear some sort of howling sound kinda of like a wo wo wo sound comming from the front of the car
By TrailerTrash
#266676 is it an automatic by any chance?
By d-mon
#266752 check your auto trans fluid, probably low.
By xjm92x
#266796 Tranny is good fluid is good to i am also haven alotttt of heavy vibration from the motor to the point where the steering wheel shakes i know have alll valve cover bolts it idk what could be wrong i almost did not make it up today also i noticed that my timing belt flaps alott on the side that goes down to the crankshaft
By TrailerTrash
#266803
xjm92x wrote:like after a while of driving if i press the gas it takes a few seconds befor the car starts moving but after that its gone but that only happens when i stop
sounds like your auto tranny is slipping to me
By goodyearrr
#268002 Im pretty sure i know what noise your talking about, this was doing it to my civic and mines a manual...
