By Jorje914
#267610 Ok I got a 1995 eg four door with 190xxx. Well living in south Florida is a must for the A/C about 4 months ago I change the coil n recharged it... Now for some reason it just stop throwing cold air. I checked the pressure and everything seams to be good. The problem I am having is that is just throwing air but is not cold. So please can some one help me out with this problem. Thanks
By necropaulis
#267622 What "coil" did you replace?? If you disassembled any part of the system without the proper machinery, you need to go to a shop to have them put the system into a vacuum or else it won't take a charge.
By RWMIII
#267673
necropaulis wrote:What "coil" did you replace?? If you disassembled any part of the system without the proper machinery, you need to go to a shop to have them put the system into a vacuum or else it won't take a charge.
X2
i am assuming he means the condensor
is the compressor engaging? or just cycling?
