By jtdyer2004
#269124 when i hold my rpms at 1600 it bounces from 1600 to 1800 kinda like a dead spot it sounds like 2 step but at a lower rpm and if i take off in first gear and it goes up to 1600 rpms just cruisin it will jerk
Any ideas?
By geitema
#269141 at the back side of the FITV valve ( located under your throttlebody ) there is a metal plate with 2 screws in it...take it off and there u see a sort of white plastic screw...turn it to its end and put the plate back.
fill up the coolant and ur fan turn on..
this must fix ur problem
By geitema
#269143 if u google it or youtube u find a guy named something like the garage guy..dont know sure but neitherway there are lots of vids for this
By RWMIII
#269155 check your FITV as stated above. Also try cleaning out your IACV.
Have you checked all vacuum hoses? Any leaks? Did you recently change or add anything to the car?
