- Fri Oct 14, 2011 12:29 am
#277672
i'm thinkin about doin this and i just have one question...What grade of gasoline do you recommend me using after the swap???
if you do the d15b7 bottom end with a z6 head and a b7 head gasket you are fine to use 87 or 89
however if you use a y8 head on a d15b7 bottom end with a stock b7 headgasket you will want to use a minimum of 89 i would run 91
the way i always judge it is anything over 10 to 1 compression is a good time to use 91 or higher
my build> blue bandit-sold=[
http://civic-eg.com/viewtopic.php?p=203107#203107
taco build!
http://civic-eg.com/viewtopic.php?t=17613
taco build!
