By 603 jdm
#281127 hey guys, i fixed my timing issue and new intake mani, iacv cleaned with new screen and o ring. new valve seals and tube seals, i was wondering if i should do another valve adjustment since i fixed the timing belt issue and if tht would help with the loss of power and burning oil under strain??? only thing i can think of is that or piston rings and if its piston rings im selling my coupe bc i dont have the time to fix tht right now.
By andyc
#281295 I had the same problem with a D15B7 of mine, I lost compression in one cylinder and burnt ALOT of oil. that was piston rings :cry:
By 603 jdm
#282387 well its so bad that it even burns about a quart of 10w30 within about 75 miles or so. and only see smoke when i take off, give it some gas to pass someone, or if it strains like uphill etc. ive even tried 10w40 and a quart still only lasts about 100 miles if im lucky. i just did valve seals and fixed my timing belt . should i redo the valve lash and set intake to 6thou and exhaust to 8 thou?
By TrailerTrash
#282390 holy balls thats ALOT of oil loss. are you sure its not smoking all the time but the only time u really notice it is when its really bad like when u get on the gas?
By 603 jdm
#282482 im sure it is, its getting ridiculous though
By HatchbackCrusader
#282483
603 jdm wrote:and only see smoke when i take off, give it some gas to pass someone, or if it strains like uphill etc.
Uh oh, I had the exact same symptoms on my D15b. Especially when I took off from a red light. A huge cloud of smoke. Turned out to be my piston rings.
By andyc
#282491 Definetely do as eg84dr says, i think youll get your answer that way sadly :(
By 603 jdm
#282605 well thanksgiving morning im gonna test the compression and if its the rings im gonna sell my coupe and get a clean coupe or hatchback, maybe just a mint shell to piece together since i got a job now. and just get a winter beater.
By Eg6H2D
#282766
603 jdm wrote:well thanksgiving morning im gonna test the compression and if its the rings im gonna sell my coupe and get a clean coupe or hatchback, maybe just a mint shell to piece together since i got a job now. and just get a winter beater.
orrrrrrrrrrrrrrr you can buy my Z6!! =]
:thumb:
By 603 jdm
#282883
eg84dr wrote:DO A COMPRESSION TEST
if its rings sell it to me :thumb:
u wanna buy my coupe ? haha
By Ahkten
#283852 This thread is quieting down a bit, but I'm having the same problem. Only thing is, I need to keep my car. how much would it cost me to fix my piston rings? would it just be worth getting a new engine? or fixing it? :S
EDIT: Sorry if it seems like im thread jacking! It's not my intention! :oops:
