By cnome
#281367 i recently swapped a d16y7 into my 1994 civic si coupe cause i blew the d16z6 rod right threw the block. and the check engine lights one and its just that it wont pic up the vtec? could it be the wiring harness or the cpu? if i got a cpu from a 97 civic where the engine came from would the check engine light turn off? and it idols at base idol and sometimes stalls. i figure i should just mess with the idoler for abit. but opinons help to!
By Fada Blayne
#281376 i do think that you have a check engine light due to the fact that you have a non-vtec motor. Also wat intake manifold did you use?
