By sipolt89
#31715 i dont know why.everything is hooked up.how long does it take to start after cranking over.i got all new fluids in so does anyone know how long it takes till it starts up.i tried starting fliuid and that didnt work either.any help will be appreciated.thanks
By sipolt89
#31716 its the first time it would start after the swap so i dont really know what to expect since this was my first motor swap
By flyinryan122
#31717 does it sound like it's getting spark? is it getting fuel?
By sipolt89
#31718 it cranks over but it just doesnt start.im kinda thinking it might be the spark plugs.i just changed them but i messed up and didnt look how they weant when i pulled them out so im not absulutly possitive how they go.i looked in the manuel and i did it how the firing order said.but that might have been for the d16 but im pretty sure there the same.
By flyinryan122
#31719 yeah there the same. And all wiring for the distributor is hooked up? and timing is correct? also when i did my second d15b7 swap i accidently put the distributor on wrong, i ended up having to take it off, spin the piece that goes into the end of the cam, then hook it all back up. it fired right up.
